I shaved all the washer squirters on my car so i have no use for the pump anymore. I wanted to have it squirt on the intercooler. Are there seperate motors for the front and rear squirters? If so can they both be turned on at the same time, I looked in the tsrm and the front is grounded seperatley from the rear sharing a common 12v power. Now if I spliced the two grounds together and ran it to the cabin on a switch. The other end of the switch being grounded should turn on both outputs. Then I wanted to run a row of 3 squirters being fed by both ends by the two outputs on the pump. How does this sound? Any other ideas welcome.
