Does the waste gate open between shifts on a manual trans? I know the blow off valve goes off but what about the waste gate?
Well, partially correct... It takes a signal from the ECU to actuate the VSV and allow pressure, from the pressure tank, to move the actuator.supra400hptt said:Shouldn't. It takes boost to get the wastegate to open. During shifting the boost falls off, just the oposite of what it takes for the wastegate to open.
are you sure it works like that on the wastegate vsv? If you follow the vac hose, it goes into the intake, doesnt that vsv bleed air away from the wastegate? If you pull that hose you will get max boost right?HotGreekInASupra said:Well, partially correct... It takes a signal from the ECU to actuate the VSV and allow pressure, from the pressure tank, to move the actuator.
