Hey guys, I decided to post this email from yesterday in here to see what other guys are running in similar applications. Anyone with a valid response please reply. Thanks!
Joe,
Ok, so in regards to the spring rating of 11.4-17.1 psi... does that mean it will be optimal to run my car at those boost levels because that's what the spring can best control and maintain boost at? I've never run lower than 92 octane gas (rated at the pump) in my Supra, and typically only run 93 octane sunoco. I figure 92-93 octane is good for about 17-18 psi max which is probably where I'll run it at most of the time. At higher boost levels, I'll be running 115 octane gas. I apologize for not knowing which scale that is going by, but it should be good for about 30 psi of boost. Which spring would you recommend? This car is a daily driver first and foremost, I don't know how often I will be turning it up to 30 psi, mainly because I don't have a roll cage in my car and will be kicked out of the track promptly after making a run at that level. I'd like whatever would give me the best combination I'm looking for. I also read in the thread that these guys are using 2 springs; a base rate one and one for higher boost levels. Can I utilize a combination like that, or is that for another type like a Tial?
Thanks,
Bob
Joe,
Thanks,
Bob
