WTH, I noticed some tiny bit of water comming out of the joint between the header and the engine block right on spot where the 6th cylinder is located.. the tiny bit of water came from that gasket... between theengine head and the header into the Turbo.
wTH is that? Does that indicate an exhaust leak? Can i use some high heat gasket selicon to fill it up and stops the leak?
