I was about to install my water outlet housing, when a piece fell out of it.
Does anyone know if this is a bit of the water outlet housing, or if its just a random piece that happened to be in there?
It sure looks like the valve from a thermostat.
Is there a temperature stamped on the end of the copper portion of it (something like 180F)?
Hmmm.
Is that a pin on the end of it? Can you push the pin in, by using force?
Can you take a closer picture, this is rather weird. :)
Edit: Just had a look at thermostat housing I have here. There is a temperature switch that looks like what is in your picture, however with the thread portion broken off.
hey Shawndude, I've put a couple of pics on a different thread, cos i didn't know how to add pics here.
It's called 'Unknown item from Water outlet housing'
If you have time to check it out it would be a great help.
