1 - 20 of 45 Posts
United States of America
water temp sensor Q : Resolution
how likely is the water temp sensor my problem?
First time cranking it, it has to crank several times to fire up.
on cold start it idles fine, close to 1000, for warm up.
after it warms up, idle fluctuates between what looks to be 500-550rpm
I've set tps, timing. checked isc, egr, plugs and wires, all vacuum lines - good
Water temp sensor has a crack around it and it wiggles. I don't, however, have code 22.
I don't want an MK4!
Wish I had an answer. If the sensor has a crack and wiggles, I would consider replacing it.
I apologize, but your mods escape me, though I know you have the ZT2 like myself.
I did add a bit of fuel for the idle on my SAFC after the Lex/550 mod was done, prior to installing the AFPR, to get the idle a bit more steady.
My goal has been to tune in closed loop to get my Vf voltage as close to 2.5 as possible.
Hopefully people with more knowledge than myself will have an answer for you.
Dan
Thanks Dan - I think I am going to go ahead and replace it. AutoZone has it $25. I haven't done the tsrm resistance check on it yet, but being cracked just above the seat and wiggling like it is, I'm thinking like you - go ahead and replace it.
Did the guy that bought your spare ZT2 get his problem fixed?
timmer - the cold start injector is another thing I'm looking at. I haven't done the tsrm check on it yet. My fuel pressure seems good and the cold start injector time switch measures good. And the idle..... is like crap @ 500~550
BTW - no codes, just the continuous flashing 'all good' :dunno:
I dont think the cold start injector is the problem, because Im having he same issue and Ive test, removed and cleaned my cold start inj. I dont know what to tell you, Im trying to figure this out too. For the time being, I set the throttle adjustment screw to make the car idle a little higher.
If you figure it out before I do, let me know.
i have the exact same problem :(
Discussion Starter · #9 · (Edited)
that's the one. i will replace it
as it listed, prominently, in each of the TCCS centrally controlled EFI, ESA and ISC
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_004.html
and your information that, it could cause problems without throwing a code
it will be a couple of days, i'll post results after.
please post pics of the location of the coolant temperature sensor. I just bought one from autozone and it doesn't seem to connect to any of the plug at the thermostat housing unit.
Now i'm all confused.
could you post pics of the location of the coolant temp sensor & the new coolant temperature unit itself?
Discussion Starter · #13 ·
this is a better picture. ecu water temp sensor has the green connector. gauge sensor is below that
ok, so I replaced mine and it didn't seem to help. Bellow 800 rpm it bounces 50-100 rpms and breaks up alittle. :dunno:
Heres the part number: 89422-12010
If I can find my trm, I will find out how to test it, because at $74 its not cheap.
Toyota only quoted $52 dollars.
Autozone price is $26. But the fucker gave me the wrong one. It doesn't even fit my god damn car. I love the high caliber people they hire working for them. They can't even tell their ass from their face.
Yea, according to autozones website, they cant get it. So I never called my local store.
http://www.autozone.com/servlet/UiB...LAR+PARTS+LOOK+UP|~COOLANT+TEMPERATURE+SENSOR
I assume its the one listed as engine temp sensor
also to test it, it is: http://www.cygnusx1.net/supra/library/TSRM/fi/FI_113.html
To test the gauge temp sensor its: http://www.cygnusx1.net/supra/library/TSRM/be/BE_041.html
on to the next page. In my paper copy tsrm its BE-36
They saw you coming man. They said this is the guy that cheaps out on his Supra and then bitches about how unreliable it is.
They just wanted to piss you off and give you more ammo to bitch about the MK3!
Not trying to jack your thread isnms.
Not sure whats up with the guys ZT2. I do want to get it sorted though, since it was brand new and mine/yours doesn't work like that.
Dan
1 - 20 of 45 Posts
