1 - 14 of 14 Posts
scksupe
how much does a stock 86.5 n/a supra with auto tranny weigh gwar on door says 4450 lbs. but other people say around 3500 which is it
I Love Lamp...
:lol: i sure hope its not 4450... it is around 3500. You have one of the lighter versions of the supra most likely. What options do you have? Leather? Targa?
i say 3400
Depends what kind of junk is in it. lol. Mine was filled with 20 lbs of trash; porno movies and mags under the seat, various boxes in the back, some free tools (broken), and a hole bunch of cig butts.
9,000,000 lbs of BOOOOST!
mine weighed in at an astonishing 3740lbs w/driver at 1/4 tank of gas
SupraStore.com
GVWR is the gross vehicle weight rating...the limit of how much the car is designed to run correctly with the most possible weight. That means that if you subtract how much it weighs as is right now, the result is how much more weight it can take while still being technically drivable
scksupe
Discussion Starter #8
sport package, so yall say that it only weighs around 3500 pounds right?
Boostless
This was posted on Supramania a while ago:
Model No. Curb Weight
2386 3561 lb.
2387 3645 lb.
2388 3535 lb.
2389 3621 lb.
2395 3550 lb.
2396 3517 lb.
2397 3601 lb.
2398 3464 lb.
Heres the model numbers
3-Door L/B Turbo 4-speed Automatic MA71L 2386
3-Door L/B Turbo w/Sprtrf 4-speed Automatic MA71N 2387
3-Door L/B Turbo 5-speed Manual MA71L 2388
3-Door L/B Turbo w/Sprtrf 5-speed Manual MA71N 2389
3-Door L/B w/Sprtrf 5-speed Manual MA70N 2395
3-Door L/B 4-speed Automatic MA70L 2396
3-Door L/B w/Sprtrf 4-speed Automatic MA70N 2397
3-Door L/B 5-speed Manual MA70L 2398
Stormcock approves
You have to keep in mind that when you get your car weighed, each gallon of gas weighs about 7 lbs.
SupraStore.com
Hood weighs around 50 lbs IIRC...dont know for sure, but I'm surprised I could pick it up and take it off by myself where I'm not even 3x that weight
I think each gallon is closer to 8 lbs
DAMN gas weighs that much? WTF!?
I Love Lamp...
It should weigh between 5.8-6.5lbs. Obviously there are factors, ive seen people say seven before too.
1 - 14 of 14 Posts
