I tried a search with no luck.
I noticed that my car is leaking coolant because it keeps drinking from the overflow tank. I decided to pinpoint the leak. I checked all the usual spots with no luck. I started the car and noticed that the leak is coming from a hose that comes out of the bottom of the water pump. It's kind of unusual. I don't just want to cap of the hose because I'm sure it is there for some reason. Any ideas, why it's leaking. Also, i'm pretty sure that the leak from the hose only started after my fluidyne install. It leaks about a drop per second only when the car is running. thanks
