1 - 3 of 3 Posts
So my buddys supra has a weird idle, It sounds like it running on 5 cyl instead of 6. Ive checked everything. Wires, plugs, ive changed the pig tails that connect to the tps, and nothing. When i unplug the tps the idle smooths out. Before it started having idle problems when you would drive it, it would run fine. But, when you would floor it, it would kinda sputter and die. Now it acts like its hitting fuel cut. the engine is 7MGE.....
Could the contacts in the throttle body for the tps make it not act right? ive changed the tps twice with two different ones and it has the same outcome.
1 - 3 of 3 Posts
