1 - 7 of 7 Posts
Hello
After installed bc 264 cams the vvti gear makes a loud noise! I was thinking that the exhaust gear was unbalanced and I purchased brand new racing exhaust gear and brand new vvti gear, installed, louder noise!!! I really don't know why it sounds like that, but it's coming from the gear.
https://www.dropbox.com/s/m85ji2oos0t1yde/VID-20160128-WA0001.mp4?dl=0
here a video of the noise and the solution to quiet it:
https://www.dropbox.com/s/g5a38c9ni5rer01/20160127_215554.mp4?dl=0
maybe the cam is bad? it was fine with stock cam, 2 different gears with same results
any suggestions are welcome
Discussion Starter #3 (Edited)
Whats you cam advance at idle? Add 2 degrees of advance and it should make it a lot quieter.
Thanks for answering
Actually I have the vvti deactivated, I can advance it, it will work? Vvti with low oil pressure like in idle works? I'm using aem infinity 506
Edit: vvti is deactivated but I have the intention to tune it, by the noise is not tuned yet.
Captain Hammer
Sometimes with aftermarket cams, the gear will knock, with it deactivated it's sitting on the stoppers, by adding 1-2 degrees you're taking it off the stoppers.
I have added as much as 25degrees advance at idle until it eventually stalled :) Sounded like it was a dragster.
Discussion Starter #6
Lol, thanks guys, I will try adding degrees to the cam, I was so confused why is making a sound like a rod is bad!
Now the issue is because I still without full vvti programming in my infinity when I try to just add 1 or 2 degrees at idle it will go up to 20 and the engine stalls
I been very alone doing all this, from the build of the engine, doing the engine harness and now the programming
Thanks all for your inputs
1 - 7 of 7 Posts
