Tonight was the first night I pushed my car through some corners. Since I've mainly drag raced the car it was never really setup for corners. I recently installed new wheels and tires and wanted to play around. The wheels measure 18x8 and 18x9.5 with 235-40-18's front and 275-35-18's rear. The suspension is completely stock. The offset for the front wheels in +40mm. The tires are Falken RT-615's.
So, with all the said, I pushed the car pretty hard through some corners late this evening. I'm surprised how well the stock suspension works even though it feels a bit soft. As I was rouding a tight exit ramp in 3rd gear turning right I hear a 'scuff' 'scuff' while hard in the corner and as the road went up and down. As the body was rolled heavily towards the left and as I went over some level changes you could feel the body move and the noise was heard. It sounded like the tire was hitting the inner fender cover.
Are there any known bottoming out issues with stock suspension Supra's while doing hard cornering?
Matt
Matt
