Ok... I hooked up a spark plug to the coils that i thought wernt firing... they are. so i took the coils that i know are firing (5 and 6) and put them in the 3 and 4 spot (where the coils wernt igniting. no change... 2 5 6 still fire, 1 3 4 dont. fuel is still spraying out of the miss firing cylinders. I am hoping to use Performance's 370 cc injectors and see if that stops the miss firing.
So i pulled out injector 1 2 and 3 and replaced them with the stock 370's... now those cylinders are firing. guess ill just run stock 370's till i can get this injector situation figured out..
so...you had bigger aftermarket injectors, and now you have stock, correct? I assume you have had to wire in new clips for the aftermarkets and then again for the stocks? Everything is correct there, right?
