1 - 4 of 4 Posts
I have finally installed the single and all is well, however, I did have a question regarding the sensor on the intake manifold. It's the furthest to the rear, and has a large hose/ pipe that ran to the stock twins. Is this supposed to be left open, or capped??
Happy Turkey Day..
if its a large hose that goes to the idle air control valve then its suppose to be either hooked up after the air filter or you can shortened the hose and place a mini filter on it. if you cap it, your car will not idle at all since it needs air due to the throtle butterfly being closed.
silvermkiv
You need to either put a short hose with a filter on it or run a hose over to a nipple on your air intake pre-turbo.
1 - 4 of 4 Posts
