1 - 14 of 14 Posts
Just with the simple set up of bpu
1.exhaust
2.downpipe
3.bcc
4.boost controller
5.boost gauge
and I guess intake if you have it.
Please post your dyno numbers or post pic of dyno sheets.
Please clearify if its auto or 6spd.
Thank you. Just wanna see the happy medium of bpu only numbers.
Old School
My car made 425 rwhp/449 rwt, 19 psi + 100 octane gas. No ice, no spraying the IC, no tricks at all.
Moderator
Ofcourse these numbers will vary from car to car, but the average Bpu 6Spd. Supra dyno's roughly 400rwhp(460 crank). Auto's usually get approximately 5% less power because the tranny robs some additional power. Also please use the search button next time, this topic has been covered numerous times :)
Later, Garon
Personally --
Straight BPU on pump gas:
373 rwhp / 401 ft lbs
BPU + cam gears and race fuel:
400 rwhp / 422 ft lbs
BPU + cam gears, front mount and race fuel:
see sig
simple BPU with stock IC no spray on it and stock intake with TRD filter element, mine dyno'd 435rwhp/455rwtq
I have the HKS triple clutch so with that LW flywheel I think it spools faster which gives better tq numbers.
1st Lieutenant Team BEYAW
Rome_The_Supraman said:
1.exhaust
2.downpipe
3.bcc
4.boost controller
5.boost gauge
i also have intake, FMIC, cam gears, and a few other goodies....the car made 425rwhp @ 19psi and pump gas, oh and its a 6spd
94 6-speed
408hp on pump gas and no ice on anything. Didn't even reset the ecu. Also this was done with 110,000 miles on it. No cam gears ect.
1 - 14 of 14 Posts
