TE27Levin said:
For high performance engines 10W30 doesnt cut it. It is way to thin. And it doesn't have the sheer resistance and durabillity of a heavier oil. The only reason it is in cars, was to conform to CAFE fuel consumption regulations. There is a story for it but i don't know it off hand. You people should all be using 20W50 in the summer. Esspecially in turbo cars.
This flies in the face of every fact out there. Particularly when it comes to syns and there resistence to high temps. Go to google, type the words: engine damage oil viscosity
In essence high viscosity oil may not be adequately pumped because of being too thick at the low temperature at which the engine is started. At start up, lower viscosity oil will reduce internal engine friction.
But that relatively thinner oil is designed to work in conjunction with the tight engine clearances and provide adequate lubrication from a cold start-up in the winter in Minnesota to a blistering drive across the desert near Phoenix in the summer. If you use a heavier oil because you think it's "better," you'll not only be wrong, you're quite likely to cause your engine some damage since it won't be properly lubricated during start-up and in cooler weather. Furthermore, if you decide that if a range of 5W-30 is good, then 20w-50 must be better because it's a wider range, you'll also be wrong, since the things done to give that oil the wider range may not necessarily be what your engine needs.
The best oil for your car is what the manufacturer recommends. Use the correct viscosity as outlined in your owner's manual, purchase quality oil from a reputable company, change it regularly, and take good care of your car.
