4721 - 4725 of 4725 Posts
Master Shit Fixer
Finally installed the G-Force ECU that I bought 4 years ago. Work and Life really get in the way of my hobbies.
From the land down under
What alterations were done to your ECU, Shawn?
Ive always wanted an aftermarket chipped factory ECU, but theyre like hens teeth to find, especially down the bottom of the planet haha
Master Shit Fixer
Agreed...I get real lucky when I found mine, and at a really good price too. (Edit) It's the 2-chip G-Force upgrade, so:
  • Rev limit raised to 9000rpm. I'll never run it that high. I just wanted to be able to get to 7500 on the track so that I had more flexibility of shift points, for example, so I don't have to shift in the middle of a turn while accelerating and holding 1.3Gs of lateral force.
  • Speed limit removed. At some point I will hit 155mph on the track and I don't want to remove my Trac fuse since it's powering other stuff and I'm against removing telltale warning bulbs.
  • Boost cut removed. No more need for the GReddy BCC.
  • Set up for stock fuel injectors (550cc), with stock lean spot removed (I think).
  • Unknown timing changes (because of the 2nd daughterboard). This is based on Wreckless's G-Force post here.
Really kindof dissapointed at G-Force's lack of markings or branding, and the fact that no G-Force ECU I've ever seen has any documentation label on the outside or inside of the ECU.
Sounds like a great setup. And I hear you re the rev limit being a huge help at the track, for a multitude of reasons too. Like not having to change up a gear so you don't hit the limiter before hitting a breaking zone.
I'm looking forward to hearing about your impressions once you have had some seat time :)
