the tt driveshaft is meant to bolt up to the tt diff, the input flange is a different size between the na and tt cars. you need the tt auto or 6 speed diff to go along with that driveshaft.
the tt driveshaft is meant to bolt up to the tt diff, the input flange is a different size between the na and tt cars. you need the tt auto or 6 speed diff to go along with that driveshaft.I got a TT driveshaft but the rubber piece between the shaft and diff do not bolt up. Like the bolt pattern of the rubber spacer is slightly larger than the diff. Is there a special spacer I need or do I need to replace something?
