1 - 7 of 7 Posts
tire killer
has the motor been changed? hg? if the guy will ask him to do a compression check before you have a 12 hour cruise. otherwise the car looks clean.
-shane
Over 10 years on SF....
Looks alright. I have only seen tan interior once before IRL.
FIX-R upper
Drive it around for 15 min and if it keeps running strong your good to go. You need to drive around for 30 min to warm up the suspention and the drivetrain, makes any sounds more prevalent.
Hardtop FTW
Very clean MKIII. I love the color. I would definately try to do a compression test before taking it, and a spirited drive around the block to make sure it's tight might not be a bad idea. Good luck!
1 - 7 of 7 Posts
