if you have stock pipes then you need to make a pipe somewhere to weld it too.... if you find a kit then it goes from the rubber pipe comming from the finder to the 3k pipe... you could have someone make you a pipe replacing the plastic pipe between the 2 rubber hoses on the upper section.... make sure you get the righ kind of falange depending on what kind of pipe you welding it on too... alluminum, steel, ect...
I got a Olympus C-700 UZ on Ebay with some accessories for just over $400. Takes great pics, I just don't usually use the best quality cuz they are huge.
