what bit or hole saw do you guys use with grease to drill the oil return line. Do you use a drill bit or hole saw? If use hole saw, there a drill bit that hole saw is attached to and that bit has to go through the surface before the hole saw even touch the surface you're drilling.
Can someone describe in detail the process of drilling the block using grease to catch metal shavings.
I did the search but only found superficial description. Thanx.
