1 - 7 of 7 Posts
The need for speed
Posted is an AEM log, should be fairly straight forward and simple to understand. Can anyone guess what happened to the motor?
I just see a couple of shifts (or letting off the throttle) with the coolant temp staying the same.
Coolant temp looks like it actally goes down tward the end to me.
StrokerClub Member
My guess is nothing....until you stopped, then over heated.
Looks like you had enough air flow through the radiator to keep cool.
The need for speed
Was sitting in a parking lot changing some settings on the AEM when my coolant temp rose due to the fans dying... I was so busy playing with the laptop that I didn't even notice the gauge increase and so I decided to take it out and do a couple pulls.. After the pulls I noticed the temps were really high. For anyone that doesn't know, stock thermostat = 180degrees and the coolant temp was 220+degrees. The temp gauge was maxed out at that point...
Temps should have been around 180-190F... I was curious if I did any engine damage so I ran a compression check which was like 170 in all 6 cylinders, so I'm wondering if I could have done any other damage?
1 - 7 of 7 Posts
