What difference to the ECU is there when you are idling, or when you are off-idle?
What I mean is, aside from a 300 rpm difference in engine speed, what happens when you go from 600 rpm and throttle fully closed to the throttle slightly open and running at 900 rpm? What things change? What inputs and outputs to/from the ECU change? What operates differently? How is timing affected? I know the TPS's IDL line opens, but thats about it. I need to know what else is happening that could make such a drastic change.
If you haven't seen my "mystery overheating" thread, that is the reason I am asking. When I am off-idle (anything 800rpm or higher), the water temp will steadily climb until it boils over. When I am AT idle (throttle closed, 600rpm), it will not only NOT heat up, but will in fact COOL DOWN from overheating condition. I can idle the car for almost two hours and it will NEVER rise above 160 degrees, if I run at 800 rpm for even THIRTY SECONDS, the temperature will start climbing. It will do this with the TPS plugged in or unplugged, btw.
