HI GUYS,
Help me out please! I have a 97 supra with 102,000 miles on the motor it has the HKS 2835 TWIN TURBO KIT, VEILSIDE INTAKE manifold,720cc injectors plus some other extras. to control fuel I have the HKS-VPC and the APEXI-AFC. I have not hade the car tuned in a little over a year so I DONT KNOW IF EVERYTHING IS SET THE WAY IT SHOULD BE. what is the safe amount of boost to run without taking any chances of blowing the motor. I always mix about 4 gallons or so of 111 octane race fuel when a fill up on 91 octane, so it is never just on pump gas.
if anybody is running the VPC & the AFC please let me know if you are local. becouse I would like to see if my car is dialed in like it should be. and I know some of you guys are saying just go get it tuned again. but the reason I dont want to do that is becouse I will be going stand alone in about 3 months. so I dont want to waist the money on tuneing before I get it. ANY HELP WOULD BE GREATLY APPRECIATED!
Thanks,
17-18 psi is always a decent amount of boost to run on pump gas. the race gas will give you a little bit better timing.
4 T's and an X
I would like to see the car someday. I have seen it around. I live right by the place where you get the race gas.
sory for getting off topic.
just wondering wat downpipes you guys use.. the rmm or the random tech with the high flow cat just because its california?
afastsupra said:
HI GUYS,
Thanks,
No one on this forum can tell u what is safe boost to run..Unless you have wide band 02..15-18psi
