·why the heck my tires kept losing air? IS it normal for air pressure drop 1 psi a day if not drived, and lose 3 psi if drived? Sometimes, it raised after drived. Sometimes it doesnt change. What the heck is causing this?
Tires will have higher pressure when hot. But if you're testing them when cold and they keep loosing pressure then you could have a couple of different problems:Suprahaha said:why the heck my tires kept losing air? IS it normal for air pressure drop 1 psi a day if not drived, and lose 3 psi if drived? Sometimes, it raised after drived. Sometimes it doesnt change. What the heck is causing this?
