basically what happens with heat soak is that when you drive your car hard for example, and then are forced to shut down for any reason such as traffic, there is a lot of stored heat energy in the engine bay that was being passed into the air, but since you were forced to shut down, your cooling has been reduced a lot because there is no longer that air to help cool. Therefore your engine gets hotter then when it was at before. that is basic heatsoak.What is heat soak?
-Alex
yeah he pretty much hit it right on.....for example if you drive your car around hard for awhile....then say you get home and shut if off...it will continue to get hotter for period of time because there is no more coolant circulating through the engine....and no air goin through the engine compartment....but the engine and turbo are still hot and heating up the engine bay temps....so when you start it 5 minutes later....its hotter than when you turned it off....;basically what happens with heat soak is that when you drive your car hard for example, and then are forced to shut down for any reason such as traffic, there is a lot of stored heat energy in the engine bay that was being passed into the air, but since you were forced to shut down, your cooling has been reduced a lot because there is no longer that air to help cool. Therefore your engine gets hotter then when it was at before. that is basic heatsoak.
-Thomas
and that can cook shit right?! LIKE OIL IN YOUR TURBO!yeah he pretty much hit it right on.....for example if you drive your car around hard for awhile....then say you get home and shut if off...it will continue to get hotter for period of time because there is no more coolant circulating through the engine....and no air goin through the engine compartment....but the engine and turbo are still hot and heating up the engine bay temps....so when you start it 5 minutes later....its hotter than when you turned it off....;
it dosent really cook stuff its just a natural thing that happens with cars...more so with turbo cars......it will cost your horsepower when you first start it back up...or a few tenths if your at the track....but dosent really hurt anything in the long run....as far as oil cookin in the turbo.....you have to be reallyyy boosting for that to happen....under alot of boost the turbo can get so hot it will actually turn red.....so if youve been running the car real hard on the boost......you have to let it idle down so the oil dosent boil in the turbo from the bearings being so hot...and yes thats what the timers are for...its one of those things that dosent happen alot.....but its best to let the car idle down just to be safe.....and that can cook shit right?! LIKE OIL IN YOUR TURBO!which is why you turbo guys have turbo timers?! i just let my cars idle for a min after i get home if i drive it hard, ive done that for years.
is there anything you could do to help with this? (while waiting at the track)I guess the big question here is, "What are we heat soaking?"
Heat soaking is exactly what it sounds like... something getting too hot, causing negative effects.
I'm most familiar with heat soaking the intercooler. That's generally from sitting at a stop light or something where there is little or no air flowing through your intercooler. The intercooler gets VERY warm, and when you first launch, you're pulling air through a HOT intercooler until the ambient air has a chance to cool it down again. It's a killer on 1/4 mile tracks when you're sitting there idling warm in the lineup for like 20 mins.
ic sprayers? or those cry o2 kits maybe?is there anything you could do to help with this? (while waiting at the track)
You probably have a bad cold start injector.My car always starts better when its hot:dunno:
It's not a bad starter when cold, takes about 2 seconds from turning the key to engine firing. But when its hot its instant not even half a second.You probably have a bad cold start injector.
mines like that tooIt's not a bad starter when cold, takes about 2 seconds from turning the key to engine firing. But when its hot its instant not even half a second.
