No turbo, no N2O, no paxton, vortech etc. If the vacuum created by the piston or the pressure fron the scoop doesn't bring it in the you are in another catagory! NO FORCED INDUCTION! Accept the challenge! Check out fusionsuprA!
Hello everyone,
Ok, I know I'm probably going to get a whole lot of heart burn for asking this question because it has probably been asked before but here it goes. I have 95 NA-T Supra, I went coil on plug with a JDM Aristo ECU set about 6 years ago. I decided to upgrade to a FFIM. I wanted to...
Lets say i run stock pistons, oem gte headgasket, aftermarket injectors new intake how much boost do you guys think i can achieve with na -t
if there is a similar thread can you please link it?
Hi everyone, this thread was started on clublexus in the sc300/400 section but it also applies to n/a supras so I copied it here.
This thread might be updated less frequently than the other one, so if something isn't working or missing also check the original thread.
This guide is for use of...
Ok not sure if this is where this goes. but my supra is NA so I guess this would be a good place for this. My question is I have a JDM 93 Supra NA/Auto. I want to know if there is something I can do to change the KM to miles per hour in the speedo. I heard of putting a resistor or something...
Hello supra people.
would someone please show me how to wire the Q45 throttle position sensor to my 1995 supra naT throttle body wiring harness. All i found so far is people trying to sell their Q45 throttle body. Any help would be great. Thankyou
