For all NA-Ters and those familiar with AEM:
what is needed to go complete standalone besides AEM 1101? wideband? harness?
does anybody have part numbers or a list of everything an NA-Ter needs?
tank yoo..
I swear, Your signature pic and quote are both just too familiar!! :lol:
Anyhow, Your goals , and finances will ultimately decide wich sensors you will want. But You will NEED a Map and an IAT sensor.
And if you want the AEM to control boost for you. A boost control solonoid. Or you can run an independant boost controller as well.
Most go with the AEM or GM sensors, although there are a few others out there as well.
Not required, but you should also have a wideband of some sort.
Also, you will most likely want some other guages as well.
And finally, Save yourself alot of stress. Unless you are willing to spend ALOT of time researching the tuning process on the AEM, A professional tuner is a must.
Good luck, Heres a start on the sensors
http://forum.aempower.com/forum/index.php/topic,3047.0.html
