Hey,
I was replacing a hole left by my lack of an antenna. So I open the hatch and open the little compartment to get in there when i found a hose, 2 hoses actually. Im not sure if they are suppose to be connected or not but they aren't and I can't figure out what they are for. One hose comes from the front and one comes from the rear. The hose from the rear sort of has a Y split in it. It split branches out midway and isnt as long. The hose coming from the front is a little bit bigger than the other hose and like i said im not sure if they are suppose to be connected or wat they even do. If anyone can help me out that would be great. I can take pictures later on if necessary.
Thanks in advance for any help! :bigthumb:
jurkey77 said:
Hey,
What year Supra? On my 1990 the antenna had two drain pipes connected to it for drainage of rain water.
If I remember right the antenna connection was heavy and black in color. What color are the other pipes? My memory is a little fuzzy but I think the drain pipes were clear (see through).
Correction: Just checked mine out now. The drain pipe is black not clear. So you have the drain pipe that splits off into a Y connection that went on two places on the stock antenna, the antenna line and the power cable with a conector at the end. Boy I forgot how small that access door is! No wonder you don't know whats going on. LOL. Hope I got it right for ya.
