·I need a new battery, what do you guys think is the best for my MKIV ('94 TT BPU++)
What do you have planned for the car? Is your main concern about starting the car and enough juice to run your stock radio? If so, any stock equivalent battery will suffice for about half as much as the higher caliber red/yellow/orange top Optima batteries. But if money isn't an issue go with Optimas!thedrew said:I need a new battery, what do you guys think is the best for my MKIV ('94 TT BPU++)
So orange top would be the choice if a new battery is needed. For me, money is not a issue.Somebody please correct me if I'm wrong, but the yellow top is not available in the reverse terminal configuration used on our dawgs. There is a orange top which is basically like a red top with higher CCA and the reversed terminals that is recommended for the supra. This info is available at the optima site.
You're absolutely right. I have an Optima Orange Top myself and am very happy with it. It also fit perfectly which is a nice plus..XCELR8 said:Somebody please correct me if I'm wrong, but the yellow top is not available in the reverse terminal configuration used on our dawgs. There is a orange top which is basically like a red top with higher CCA and the reversed terminals that is recommended for the supra. This info is available at the optima site.
Where did you get the Monster cables for your battery? They didn't come with the Optima did they?supra400hptt said:I just got the orange top. Seems nice but the plastic spacer that I got with it was still a 1/4 inch too short. I ended up using two pieces of 5/8 particle board as a spacer now all is good. There is a pic on my web site. Terminals are monster cable.
