1 - 7 of 7 Posts
lol seriously? a maf cleaner that says specifically not to use on supras??? lol!
i believe that can would be talking about the mkiii supra turbos that use a Karman vortex MAF and that cannot really be cleaned with a maf cleaner, and can be killed if using a chemical cleaner on them,and is kind of useless as you cant reach much of anything with the plastic shielding the mirrors and sensors..... you should be fine to use a normal maf cleaner on the mkiv maf i believe.
someone correct me if im wrong.
i believe that can would be talking about the engines that use a Karman vortex MAF and that cannot really be cleaned with a maf cleaner, and can be killed if using a chemical cleaner on them,and is kind of useless as you cant reach much of anything with the plastic shielding the mirrors and sensors..... you should be fine to use a normal maf cleaner on a hotwire maf.
done, the obd-i 2jz-ges came with karmen vortex sensors but the 2jz-gtes were hotwire.
1 - 7 of 7 Posts
