1 - 20 of 28 Posts
200+mph
and I don´t mean what brand. I mean what kind ?
I have a Mkiv Supra TT BPU++ and I was thinking what kind of oil I should use
btw boost is set at 1.2 bar(17.4 psi)
10w40 semi synthetic ???
Sry if this has been asked a thousand times before :) but the search thingy sucks
10w 30synthetic.... Redline or amsoil...
It's on your engine...
BPU is so 1997
I think about 90% of the people on here use Mobil 1 (full synthetic) 10W30. Some go with a heavier weight because of warmer climate or some oil consumption issues though.
200+mph
btw i forgot one thing. The shortblock and head are only driven 700 miles so this will be the first oil change since the new motor was put in. I am gonna change the oil at 1000 miles
so true
other 10W30 synthetics to look at
are:
redline
royal purple
amsoil
castrol
i have used all in all my turbo cars with no problems
greddy has a new oil out but i have not seen any feed back on them yet.
BoosT AddicT
:werd:
BPU is so 1997
I would break the motor in with conventional motor oil first in that case. Although oil manufacturers claim that is no longer necessary with their new formulations over the years.
200+mph
so i shouldn´t use Mobil 1 (full synthetic) 10W30 now??? how many miles does it take to brake in the motor ?
ur moms favourite
Valvoline is another highly trusted and proven brand, outperformed mobil1 in a big oil test i saw recently, redline was constantly near the top with the valvoline, and royal purple was nowhere to be found.
Hmmmm...I thought it was because of the CNC machine tolerances being so tight.
200+mph
Discussion Starter · #16 · (Edited)
how many miles does it take to brake in the motor ? when is it safe to gun it to 7000 rpm ?
ur moms favourite
80% of the engines break in is done in the first 20 miles, so break in really isnt too important any more. I'd say run break in oil, low boost and no more than about 5k rpm for the first couple hundred miles, load it up, then back off, keep the revs varied and dont drive it too easily - cylinder pressures help force the rings to bed. Then swap if out for the synthetic of your choice (make sure you're going to stick with it), and just drive it like you mean it :)
Replace your oil and filter again after about 1000miles.
any links to this .. seems like a good read.
ur moms favourite
I think it might be in pdf on my home PC, will check when im back there in a few hours and post it here if i find it
any new ?
1 - 20 of 28 Posts
