1 - 10 of 10 Posts
Instead of polishing a bunch of engine parts which would fade away sooner or later I want to chrome them instead. The question is what can be safely chromed and what should I polish. So here is the list of parts.
Turbo Cartridge
Intake Manifold
Upper Radiator Pipe
Cam Covers
Intake Pipe
Intercooler Piping
Catch Cans
Vacuum Manifold
Fuel Rail
Don't bother with chroming. Do a ceramic coat instead. Looks nearly as good as chrome, and will prevent heatsoak to boot. Here's a pic of some ceramic coated pulleys and brackets to give you an idea..
I always thought that ceramic coating has this matte finish to it. At least every job I have seen has a little wavy surface and not enough reflection. Where did you do yours?
My question still stands though. Can I chrome/coat turbo cartridge and intake manifold?
488ci V10 Power
I had 30+ parts chromed on my supra with no problems.
Turbo Cartridge - YES (not the exhaust housing)
Intake Manifold - YES
Upper Radiator Pipe - YES
Cam Covers - Cant chrome plastic
Intake Pipe - YES
Intercooler Piping - YES
Catch Cans - YES
Vacuum Manifold - YES
Fuel Rail - YES
Yes, you can. It's called vacuum metalizing...
Shawn Davis
Technically you can also plate plastics using electrodeless (or electroless) plating processing. Vacuum deposition is the typical method to deposit a seed layer and then you plate after the initial layer is down.
1 - 10 of 10 Posts
