All of it can be removed -->
You'll need block-off plates for the head and the intake chamber. Be sure to install the appropriate resistor if you haven't already (when you do the normal, BPU EGR-disable mod). If you have the Sound Performance fuel system you will use the fuel pressure guage mount to double as a block-off for the manifold. You COULD remove the EGR passage from inside the manifold, but I think it would be nearly impossible without sawing open the top of the manifold, then re-welding it.
Steve
Steve
