1 - 7 of 7 Posts
SupraForums Sponsor
I found that my bolts backed out a little from the turbo and one bolt was almost all the way out. Here is a pic of the after effect:
SupraForums Sponsor
Discussion Starter · #2 ·
Obviously this caused a major leak there. Was putting too much anit-seize on the bolts the problem you guys think? What should I do when I put the new seal in? I didn't loc-tite them at all because they get loc-tited themselves very well.:) If I wanted to get the bolts off you know they would have been stuck on there, but since I didn't want them off...they turned themselves off.:rolleyes:
when I installed my turbo on my DSM i did not use either anti-seize or loc-tite on either of them, just torqued them down nice and tight. It is a little bit of a pain when I had to take it back off do to an oil leak, but a nice long wrench was able to remove it. I am not sure how easy supra turbo bolts are to get to so I am not sure if removing them and install the bolts are a pain or not.
If your going to use anti-seize just use a small dot and use your finger to rub it around the treads.
boost is good
performance disatvantage- might have hurt your spoolup some since with the leak not all the exhaust gas/energy was hitting the turbine
i havent ever used anti-seize or loctite on any of my turbo related bolts before..just torque them down nice and tight...and also use a lock washer in front of the nut or bolt.
just double check them after a few heat cycles and make sure they arent backing out and you should be good to go.
agreed on the lock washer
i always anti seize with mine though
never had a problem of them backing out
Aside from the lag and lack of exhaust gas to spin the turbo due to the leak, I think you'd see a huge rise of underhood temps.
1 - 7 of 7 Posts
