Status
Not open for further replies.
1 - 16 of 16 Posts
all stock no DPs or exhaust, what is recomended for a good launch? if you got a stock supra what is your sweet spot? Im still trying to find a good range to have a good launch and im getting 4k is good, but then i think i should go a little higher..
well if you think you should go a little bit higher then go a little bit higher! Youre not going to hurt anything as long as you remember to preload the drive train so you dont break anything.
how do you preload the drive train, havent heard of this i dont think.. you mean like warm it up?
how hard is it to share what your sweet spot is? 4, 5k 3.5k
There is slack in the drive line and when you lauch the slack is immediately taken up by metal to metal contact. This causes metal parts like gears to bang together and potentialy chip a tooth, crack.... It you take up the slack by brake boosting or a similar technique its alot easier on your drive line.
do you mean "boost braking" ????? :dunno:
or brake boosting????
maybe?
Supra Owner Since 1996
You should be slipping your clutch on the launch which, will in its self, preload the drivetrain. If you don't slip the clutch your either going to spin or bog. Preloading is still a good idea, but just as an FYI the Supra drive train is not metal to metal. Six speeds have a rubber dampened flywheel and a hard rubber puck between drive shaft and 3rd member.
Discussion Starter · #13 ·
ok thanks , now i know what preloading is, i and my friends usually call it riding the clutch
OOO... i've never launched my supra before. but im sure the previous owner did. everytime i shift i can hear and feel play in my driveshaft, so i was too afraid to play with the monster. but the driveshaft is in good condition. there seems to be play somewhere along the driveling.. the differential or the tranny. and this can be cause by launching without preloading the drivetrain(riding the clutch?) correct? who would know whats wrong? and everytime i shift gear i hear this sound like metal banging. after i let go the clutch.
1 - 16 of 16 Posts
Status
