Senior Member
I'm trying to run new brake lines on the mkiv. I believe the fittings are 10 1 and the line is a -3. Does anyone know where I can buys these? I need 2 T's. I've tried searching summit with no luck. thanks
Senior Member
Discussion Starter · #2 ·
Well. Just in case anybody else desides to do what I did (replace all the brake lines with steel braided lines) and needs to know what size the brake fittins are....10mm x 1 and the lines are -3. You will have to get adapters that are male/male 10mmx1 to -3 and run -3 fittings off that. Have fun. :)
