nope, i found a 33m and it doesnt fit too small it's actually a 34mm. well not really but i hammered it on and its in there. I used a breaker bar, cheater bar, and 100 lbs of psi. and yes i pushed out the indintation on the nut. what am i doing wrong? do i need a specialty tool or cranck up the psi to 200???:scratch:Boost Junkie said:Try a 1 5/16" 6-point.
You may be right. I am not sure about NA diffs. it is a 36 on TURBO. Might be smaller on an NA. In any case, use a 6 point impact socket if you can get one. It will save you some headache. Good luck, let me know how you get it off.supradriver247 said:thank you, the 36mm seemed to big, but ill try again. im using an iron rod through the hole (bent two screw drivers already). are you sure its 36mm 6 point? I fitted a 35mm and seemed too big. Mine is the na 5 speed open diff(not sure if that makes a difference).
Look at the size of his forearms... looks like you also need a proffesional body builder to help u out.Rotarytoy said:
:wtflol: :bigthumb:piwko4 said:Look at the size of his forearms... looks like you also need a proffesional body builder to help u out.
