i am thinking about getting some 18" for my supra, i just don't know what the offset/ width combination to use. I heard the sizes for turbo's aren't the same for nonturbo. So what should i be looking for in dimensions.
I was think about lowering my car using the eibach lowering springs. I'm assuming that will affect what size tires i can use. I been looking at 18's and trying to figure out the offset and the widths that are possible. Looking to spend 1800 or less. I know that's going to be hard but that's what i could afford. Anyone got any suggestions???
Does your budget include the tires? I paid $2200 for SSR GT1s with dunlop tires from Tire rack, 18X8.5 front and 18X9.5 back, i think, been some time. So if your budget does not include the tires, u have a huge selection to choose from.
in fact, my budget does include tires. i think that's what narrows my choices. I really don't care for name brands. I really don't see the benefit for name brand. If you see any benefits, please feel free to mention it.
Tires are important! Cheap ones will give you the look but not the performance! They will be difficult to balance, wear quickly, not work in the wet, cold, etc. You will get better performance from a 17" set of lightweight wheels & quality tires than big, wide cheapies
Hi everyone, this thread was started on clublexus in the sc300/400 section but it also applies to n/a supras so I copied it here.
This thread might be updated less frequently than the other one, so if something isn't working or missing also check the original thread.
This guide is for use of...
Hello everyone,
Ok, I know I'm probably going to get a whole lot of heart burn for asking this question because it has probably been asked before but here it goes. I have 95 NA-T Supra, I went coil on plug with a JDM Aristo ECU set about 6 years ago. I decided to upgrade to a FFIM. I wanted to...
Lets say i run stock pistons, oem gte headgasket, aftermarket injectors new intake how much boost do you guys think i can achieve with na -t
if there is a similar thread can you please link it?
Ok not sure if this is where this goes. but my supra is NA so I guess this would be a good place for this. My question is I have a JDM 93 Supra NA/Auto. I want to know if there is something I can do to change the KM to miles per hour in the speedo. I heard of putting a resistor or something...
Hello supra people.
would someone please show me how to wire the Q45 throttle position sensor to my 1995 supra naT throttle body wiring harness. All i found so far is people trying to sell their Q45 throttle body. Any help would be great. Thankyou
