This is good suspension info, guys, keep up the good work. FYI - I ran a Solo II autox (my first) 2 weeks ago with this setup:
Eibach/Koni (Konis 1 click from soft, F&R),
BFG R1s on stock wheels 255/275, 44f,42r pressure, camber -1 F, -1.5 R, toe 0 F, 1mm total in R, caster 5. TRD front strut bar, no rear (now have one), stock sway bars. My car is a 97 6 spd. with 35K, BPU. I was understeering badly in the slow corners especially, partly because I thought the turn-in would be better than it was. Surprisingly, the tire temps in front were very close to even. I'm going to experiment with sway bars now and hope to avoid the coilover route. I'm used to driving shifter karts with neutral or oversteer balance, so this was an eye opener. Nothing like starting over. Any comments on getting by with Eibach/ Konis? I now have TRD sways and the heavies on order. Money's not the issue, daily drivability is. Thanks, Jeff B. in Colorado
