1 - 9 of 9 Posts
In the market for some new rear tires. Looking for a good summer tire for the street rain/dry (not R compound) that can take a 2nd gear(bpu)pull without breaking traction. Also looking for good tire tread life. What do you guys recommend? Thanks:)
All depends on what size you need? 17", 18" wheel? Also alignment setting can make a world of difference on rear traction at bpu levels. Depending on rwhp, its possible you'll still break traction in the dry at the top of 2nd.
Possible options:
Michelin PSS (great tire for long tread life and wet traction, but expensive)
Continental Extreme Contact DW
Bridgestone Potenza S-04 PP
Game Over
I have Pirelli P-Zero Rosso's that are about 3 years old when I got them. They are 315/30/18's in the rear, and they could not hold 2nd gear at BPU+++ at all. They did okay once they were warmed up. Wet traction is worthless. They also come with 220 tread wear ratings. I would probably look into the Michelin PSS, because they have better all-around traction, and their around 300 tread wear for better longevity. Maybe if the tires weren't as old, it would've probably performed better when I got them, but for how much they are worth, I was hoping they'd do better.
Master Shit Fixer
Yes, yes, yes. Michelin Pilot Super Sports are what I use. I drive my car to the track, at the track, and home from the track on these. My rears are 285 wide & 18" diameter (can't remember the aspect ratio right now), and they hold 2nd gear WOT just fine on dry pavement.
+1 mpss. my 401hp/433tq 93 6spd held traction like no other. i swear by these tires. but this time I'm running 275s Continental Extreme Contact DW on the stock wheels for my 98. hopefully they are just as good.
Discussion Starter #6
Let us know how the Continental tires do:)
will do!
Michelin PSS here. They held great at BPU levels and are ok at APU levels. My first set of rears lasted me about 20,000 km over 4 years. Just got another rear set this past summer. Got the first set for $1400 then rears just now for about $700. 285/35/18. Also if you get caught in the rain they can keep you on the road. I had some p-zeros a while ago and spun out on the Hwy 401 in torrential rain. Nothing happened thankfully, but I never went back to those tires. Conti's were ok, but the PSS are well worth it and the best all rounder.
Discussion Starter #9
Thanks knan:)
1 - 9 of 9 Posts
