so i have the ever popular code 42. also have/had abs code 31.
-replaced the FR abs wheel sensor (code 31) cleared still pops up..?
-my cruise control doesn't work and i occasionally get wacky shifting in the auto.
-tach works, speedo works, odo works(well it at least counts miles)
just now i did the splice for the odo pink wire to blu/red, cruise control now works but i still get the wacky shifting..side note assuming ill need to order a new odo?
where should i go now? replace the VSS's on the tranny? have to ask my mechanic but im pretty sure he checked them and they checked out ok, he even switched them around(same part number) and nothing changed.
Master Shit Fixer
I'm no expert on the auto trans but if the odo pink wire mod fixed your cruise control, then I guess it's possible that the speed signal isn't making it to other components as well. Before you order a new odometer, you might want to give this a try:
http://www.supraforums.com/forum/showthread.php?1024553-WTB-Your-busted-Odometer-(actually-I-want-to-repair-it)
Boost Junkie
I'd personally just get a new odometer.
Steve K.
Master Shit Fixer
