1 - 7 of 7 Posts
200+mph
Hi I have a Mkiv Supra Twinturbo. And I was wondering because the engine and gearbox are not in the car and everything is disasembled because the new shortblock and head are about to go into the car
maybe I should use the opportunity to upgrade something but not to expensive but gain a few horsepower and maybe buy something that i´m missing and could be usefull to have
What should I buy?
so here are the things that are in the car
Downpipe Hks 4" exhaust
FMIC
Greddy Pofec B boost Controller
Hks Pipes to the Intercooler
Hks Fuel Cut defencer
Cone Air filter
Blitz Dual Turbo Timer
Fidanza racing ligthened flywheel
copper/ceramic Clutch
Titan Motorsports 2JZ Cam Gears
Greddy Iridium Spark Plugs
Apex S-AFC II Special Edition
ARP Head Stud kit mkiv
Boost gauge
Well you could eliminate your MAF sensor with a VPC, MAP ECU, or stand alone computer like the AEM EMS. But if you are not planning on going single, honestly I would leave your setup the way it is. Just tune the fuel curve and enjoy a healthy BPU+ car.
200+mph
no suggestions? I was thinking maybe HKS Camshafts 264° . and maybe buy a blow off valve , bigger injectors or something like that. What would you suggest in the elctronics department ?
Definitely a BOV! Shoulda done that first! You seem to be looking for just more power with ease. How about lightened pulleys and a BL dampened crank pulley? Maybe some more monitoring gauges. DEFINITELY an EGT gauge, and a nice wideband O2 sensor w/display. If you DO get cams, make sure you do some head work while you're at it.
A BOV at BPU levels gives zero performance benefits. The stock one holds (very well) all the boost that the stock twins can generate. If you want sound effects, then that's another story.
I was under the impression that the stock BOV is a bit of a gamble at higher boost levels(15 and up).
Luvs ( . ) ( . )s
You said in your post the HKS pipes to the ic, I'm taking that as your going to upgrade to hks hardpipes. Why not just do a full blown 3 row or something. That will help.
1 - 7 of 7 Posts
