1 - 14 of 14 Posts
I searched and have read around trying to find out as much about the MKIV as possible. Ive been in the market for one for a few months. Ive narrowed my choices and Ive almost completly decided to get a TT, 6 speed.
Ive been into DSM's for about 6 years, and know what it costs to keep one of those going (alot), and I wanted to hear from Supra owners. How much does it cost you on a monthly average to keep your BPU+ car running? Also, are you running into re-occuring problems? i.e I have replaced a transmission every year Ive owned my AWD.
If you were going to look at a Supra to buy, What would you be looking for?
This is a section from another site enjoy.
"What should I check when looking at a Supra to buy?
-Have someone cold start the car while you stand behind it watching the tailpipe, and look for gray smoke with a blue-ish tint (easiest to see in direct sunlight)
-Let the car warm up and continue to stand behind the car checking for smoke
-Now move to the front of the car, and open the hood. Listen for bad noises (Noticeable Injector Ticking is Normal)
-Now go back and watch the tailpipe for smoke, have someone blip the throttle, while you watch for smoke, let it idle between the blips
-Now do the same but have them mash the gas and rev it up till like 5000rpm or so
-Now have a friend follow behind you in another car while you go for a test drive
-Have him watch for smoke while you drive
-Put it in 2nd gear, let the rpm drop to about 1500, and then stomp on it, and stay on it till redline, then let off the gas. Your friend should be watching for "gray/blue smoke". Just grey/black smoke is ok.
-Smoke at cold start-up, leaving a stop-light, or throttle blipping from idle is valve stem seals. Smoke under boost, or after letting off of boost, or maybe when revving full throttle, is turbo seals. Smoking for no good reason, or if it doesn't stop pretty quickly is piston rings (may get better or worse when hot).
-Your job while at full throttle in 2nd is making sure the turbos boost fine (smoothly), that you can feel full boost by 4500rpm or near it, and that you don't hear bad noises (slight turbo whistle/whine is ok, if it has an intake it will be noticeable)
-Use all the gears in the transmission, and make sure it shifts fine (if it is a 6spd, it is going to feel and sound clunky too you, that’s normal. If the transmission makes "ball bearings in a can" sounds at idle or low speeds, that is 2-piece sprung flywheel and is normal)
-While driving with the windows down, listen for clicking or popping noises coming from outside the car. (A POP when starting or stopping, or making a sharp low speed turn (maybe up a hill), is the drivers side engine mount. A clicking sound under initial mild acceleration or deceleration, that lasts for only a second or two then stops, and sounds exactly the same regardless of speed, is the rear upper control arm bushings. A clicking that changes with speed is wheel bearings)
-Make sure the brakes work smoothly and reasonably quietly. When coming to a stop take your hand slightly off the wheel and make sure it stays straight.
-Make sure the car tracks straight on flat roads.
-A creaking noise from the hatch when turning up hill, means it needs rubber hatch bumpers.
-Rattling from above you means the targa is loose (make sure the targa bolts loosen, and tighten back down smoothly) and make sure the targa wrench is there.
-Make sure the rear hatch opens and closes fine, and that is stays up on it own.
-Make sure all the doors open and close smoothly
-If you can really smell the exhaust when coming to a stop, it has no cats
-If when flooring it, the car pulls smoothly till ~4000rpm, and then rockets forward like getting hit with a semi, then it's BPU and not stock. If you can hardly feel a change over from the 1st turbo to both, then it's stock.
-When checking under the car for leaks, don’t be alarmed by an oily sludge on the transmission and differential. That’s a greasy undercoating that Toyota applied. But check for fresh oil leaks, and check the rear CV joint boots for cracks.
-If possible, look at the spot where the car normally parks. Check for fresh oil puddles or spots. If they say their other car caused the spot, don't believe them if it's a clean 1-2 year old car they are blaming it on.
-Check the wheel rim, inside and out, for curb rash or bent rims.
-Check for excessive or uneven wear on the tires
-Check for cheap, or miss-matched tires
-Look to see if all the little plastic panels and parts under the car all line-up, and are attached, and that paint is not where it shouldn't be (cracked under trays are not uncommon, don't be alarmed). Spend a fair amount of time on the ground, don't be afraid to get a little dirty. Also all the major body panels have the original VIN number visibly stuck on them, make sure they are all still there and are the right number. Look for missing, non-original, or out of place fasteners. All these things are possible signs off a collision.
-Check for signs of rust in the wheel wells and inner fender
-Check the condition of all the exposed rubber on the suspension joints
-Make sure the power steering is smooth and quiet
-Make sure the gaps in the body panels are all even.
-Walk all around the car, and look at each panel at different angles. Looks for small dents and dings, and make sure the paint matches all around.
-Look over the paint condition very closely
-Check around all the glass to see if it has been replaced. Check the manufacturer information on the glass to see if they are all the same.
-Make sure all the exterior lights work
-Check the headlamps for cracks, moisture or fogging/yellowing (expect them too be fogged/yellowed if an earlier model)
-Make sure to test every last switch in the car to make sure it works (power windows, locks, turn signals, light switch, dome lights, power seat, cruise control, everything). Use all the functions on the A/C and make sure they all work. Go from HOT to COLD A/C and make sure it's getting very hot, and very cold. If it has a factory alarm, make sure the key-fobs work.
-Check the interior for excessive wear (cracked leather in the seat's side bolsters is pretty damn common).
-Check all of the fluids, make sure the fluid isn't terrible. Open the oil fill cap, and look inside for sludge build-up (you shouldn't see any)
-Find out what oil the use, and how often (don't trust their answer unless they have receipts)
-Ask them if they have had any work done to it. If they have owned it for several years, and say they have done nothing to it, don't take that as being a completely good thing.
-Ask if it has ever had modifications, and what.
-Make sure it still has the spare tire, jack and wrenches, owners manual, and targa wrench.
-Try to get the repair records
-Do a Carfax.com check on the VIN #
-Take it to a mechanic you trust AFTER you have done all this to get it checked out one last time before buying it".
No matter how good the car seems dont get excited and buy it right away.
Dont buy a modified car, the reason they were modified is pretty obvious.
Dont buy a car from a guy under 20 or even older.
Check the rotors to check wear to make sure it corelates with the mileage as it is very easy to disconnect the odometer...
I pretend to be fast
you can also change the rotors so that it would look like less wear
Purchase a stock vehicle. Preferrably a 1 owner car. Go to MKIV. com & TO4.com & read, read, & reread.
Get owners records & verify maintenance was done as described. Follow the advice already given in this thread.
Good Luck!
1 - 14 of 14 Posts
