1 - 3 of 3 Posts
Hey fellas so I'm getting my engine rebuilt with manley h tuff rods and manley pistons arp main and head bolts. I have a s366 tubo,id1000 injectors and gsc s1 cams. I will also be using aem meth kit with 50/50 boost juice. What would be a safe amount of boost to run and what kind of power do you think it could make its hooked to a th400 trans thanks
Depends on compression ratio, octane with meth and rev limit? If stock 8.5 you can probably run up to 25psi around 600whp. I'd recommend having your tuner take care of that info for you. If it's just a drag racing car maybe you can run even higher boost pass after pass.
1 - 3 of 3 Posts
