·Whats the most hp that u have seen or heard of on a supra?
::MySTiK_[SuPRa]:: said:I believe Chris (SP Black Bird) from SP Engineering
did 700rwhp at 2.05bar (= 29psi) on 91 octane on his
hks 2835 equiped supra.
29psi on 91 octane::MySTiK_[SuPRa]:: said:I believe Chris (SP Black Bird) from SP Engineering
MKIV4Door said:29psi on 91 octaneare you for real?
silvino said:The question needs to be clarified. You can do silly shit on a dyno and never get to use it withotu blowing the motor (like 2 bar and 91 octane). The reason so many of us think it's llame to do that is because the car won't last while being used of setup that way. You can do it and say you did but it doesn't mean jack shit. That's the problem with it.
Wordsilvino said:The question needs to be clarified. You can do silly shit on a dyno and never get to use it withotu blowing the motor (like 2 bar and 91 octane). The reason so many of us think it's llame to do that is because the car won't last while being used of setup that way. You can do it and say you did but it doesn't mean jack shit. That's the problem with it.
It's pretty sad if you believe that. One long pull on the strreet and he would have been sitting next to his car on the side of the road. Even after the dyno pull, I suspect he did internal damage that just wasn't immediately obvious.x X CLoud X x said:yup i remember when he ran 29lbs on pump..... he proved everyone wrong
