·anyone know the specifics, if it makes a difference, the ecu is obd1 auto, and the harness i found is a 95 6 speed . anyone with knowledge about this, please let me know, thanks alot!
Red Supra said:Your 6spd harness wont shift your automatic tranmission. But it works the other way around. Better find a 93-96 auto harness.
You can also run an auto ecu in a 6spd car without a problem.
Red Supra said:You wont have problem, it's plug and plag all the way. I used an auto g-force ecu in ex 6spd car while my ecu was in the mail. thanx Larry, what a nice guy!
Red Supra said:You are right supra auto ecu does retard timing during shifts when the trac fuse is in place. Pull the fuse and timing retard is gone. Since turbosupra is swaping the 2j into something else besides a supra he will probably do away with that silly traction control device altogether.
