....I have a jdm 2j in mind, I wanted to know what is the more power you can get from the twins ..... safely?...
I don't know if you can "safely" push the JDM ceramic wheel turbos much over 16psi and expect them to last. So I would draw the line at under 400whp for the JDM turbo setup.With easy bolt on stuff (not modifying the turbos, no external wastegates or morting the manifold, etc.), and 93, you can get upwards of 450WHP.
thanks man... sound adviseI don't know if you can "safely" push the JDM ceramic wheel turbos much over 16psi and expect them to last. So I would draw the line at under 400whp for the JDM turbo setup.
93 octane and 450RWHP may be a little optimistic. Possible, but not likely. But very possible to do some engine damage with that much boost (to make 450whp on stock twins, you're looking at 20lbs+) and 93oct.With easy bolt on stuff (not modifying the turbos, no external wastegates or morting the manifold, etc.), and 93, you can get upwards of 450WHP.
Thanks... It's somewhat what I was thinking..... I'll just put the single on from the get-go and be done with it.93 octane and 450RWHP may be a little optimistic. Possible, but not likely. But very possible to do some engine damage with that much boost (to make 450whp on stock twins, you're looking at 20lbs+) and 93oct.
IMHO, the key factors to making good power on stock twins (in regards to USDM TT), is a healthy motor, and healthy stock TT system (on boost leaks, etc) + high boost, and sufficient octane so that the ECU does not pull any timing.
Here's a good thread in the dyno section:
http://www.supraforums.com/forum/showthread.php?t=427097
