I have an RPS Stage 2 clutch and Fidanza Flywheel. Just a couple days ago this started. The clutch feels pertty light and spongy, and when the engine is running, I can feel a tiny bit of vibration through the pedal when I press it down. It has also become very hard to shift. I have to press the clutch all the way to the floor, which isn't required normally.
The shifter is very hard to move in and out of gear when shifting, also. First gear and reverse are the hardest. Reverse gear takes two hands to move it into!
I bled the clutch lines thoroughly, which didn't help, and am replacing the master cylinder tommorrow. The slave cylinder was replaced in January. Any other ideas? Thanks.
