Status
Not open for further replies.
1 - 20 of 96 Posts
Please post any wheel questions in here. We're getting 2 wheel questions a day, often asking the same information...
Can I fit (insert tire size here) on the (insert wheel size here)?
I don’t know. Go look for yourself. Tirerack.com lists tire specs for each model of tire. Search for the tire size you think you want and see what tires come back from the search. Then click on “specs”. You’ll see a chart listing all available tire sizes. For each size, a rim width range is provided. For example, Dunlop SP 9000’s specs are here: http://www.tirerack.com/tires/Spec.jsp?make=Dunlop&model=SP+Sport+9000 A 225/50/16 tire can fit on as narrow as a 16X6 wheel, or as wide as a 16X8 wheel. A 275/40/17 tire can fit on a 17X8.5 wheel up to a 17X11…
But each tire is different, and they all have different specs. Here is a BFG drag radial spec sheet: http://www.tirerack.com/tires/Spec.jsp?make=Dunlop&model=SP+Sport+9000 A 255/50/16 can fit on the stock sawblade (16X7). But if you look at a 275/40/17, the rim width range is 9-11”, not 8.5-11” like the Dunlop SP 9000
What is the stock bolt pattern?
5X114 (4.5”)
What is a wheel offset?
http://www.tirerack.com/wheels/tech/offset.htm has some basic information on wheel offsets. The stock sawblade offset is positive 35. MKIV wheels have a positive offset of 50. If you want to run a 10” wide wheel you should at least have a 45 offset.
Also check out Steve Jarvis' wheel fitment page (designed for MKIV):
http://www.geocities.com/steve_jarvis_me/Fitment.xls
How much do (insert wheel here) weigh?
http://www.fd3s.net/Reference/wheels.html Has a chart with Aftermarket wheel weights listed by size…
http://www.myalfa156.com/wheels/wheel_by_carmake.html
Has a chart with OEM wheel weights listed by size
Thread links:
widest tire on stock sawblades:
http://www.supraforums.com/forum/showthread.php?s=&threadid=110782
http://www.supraforums.com/forum/showthread.php?s=&threadid=110740
MKIV wheels:
275 tires:
http://www.supraforums.com/forum/showthread.php?s=&threadid=110019
http://www.supraforums.com/forum/showthread.php?s=&threadid=107562
Cobra wheels with 315's:
http://www.supraforums.com/forum/showthread.php?s=&threadid=110040
What offset rims?:
http://www.supraforums.com/forum/showthread.php?s=&threadid=109289
Rx7 vs MKIV vs 300ZX wheels:
http://www.supraforums.com/forum/showthread.php?s=&threadid=108992
Wheel widths:
http://www.supraforums.com/forum/showthread.php?s=&threadid=108277
S
anyone know if there is a dealer in the USA for "work wheels". its a european wheel company. or does anyone know of how to contact them?
///M3 > MKIII
Re: Rims....
SupraBadBoyMKIII said:
HEY GUY I WAS WONDERING IF ANYBODY CAN TELL ME IF THESE RIMS WOULD FIT without RUBING OR CAUSING ANY DAMAGE.... I KNWO THE STOCK OFFSET IS 37 AND THESE ONE ATE A 27 OFFSET
HERE ARE THE RIMS....
http://www.supraforums.com/forum/showthread.php?s=&threadid=109984
THANKS
is your car lowered at all?
I think you will be fine... with my 18's w/275's on H&R springs I rub the inner fender liner on front fenders just a bit.. but that is all
R
Check this out (rim matching much like tirerack.com)
i found this site the other day from my friend.
im not sure if this has already been posted but whatever itll get posted again. go to www.dirtcheaprims.com
at that site you can see various rims on an mk3 supra
along with lower it change the color etc of the car.
over all it is pretty dope. click on "rims" then scroll down
and click on racing harts and then click on one of the rims in there
and click view on car and pick model make etc.
that is the for sure way i know how to get to the car view screen
S
anyone know who make those wheels and a number or site, place who sells them?
19x10 with 285's on a MKIII !
My bro and i were messing around yesterday, we put some Racing Harts on his car with no rubbing. He's running with Tokico springs i believe. Here are the sizes:
Fronts 18x9 (48+?) 265/35/18
Rears 19x10 (50+) 285/30/19
The rears were pretty maxed out, anything with a smaller offset than +45 will probably not work unless you cut the fender. The fronts slighty touch the fenderlining when the wheel is at full lock, but no rubbing is audible on a U-turn. I have some pics if somebody wants to host them.
deadbeat extraordinaire
that car is f#cking beautiful i love the paint color and those rims really match the car nicely.
rpo1
does anyone know if rpo1 18x 9.5 w/ 45 offset, would rub or the rim touch on the inner side? or are spacers used?
running tok and suspension tech.
Madd Tyte JDM yo ®
I looked on that wheel weight page and still wanna know:
What is the Weight of the MA71 5-star 16" rims?
Discussion Starter #20
SlowMo said:
are mk3 wheels same lug partern as mk4?
Yes as far as I know all toyota/lexus 5 lug wheels use the same bolt pattern, and is also shared with ford, mazda, and Nissan 5 lug wheels.
1 - 20 of 96 Posts
Status
