1 - 20 of 47 Posts
SF's Cleanest
I know this is a long thread, but if you know anything about wheel fitmit and have a few minutes to help me out I would really appreciate it.
Well the time has finally come and I'm getting rid of my stockers and picking up a set of CCW's.
What I didn't realize until today is that I really have no idea what sizes do and do not fit without rolling the fenders.
I searched around and found some good info, but I just want to be 100% positive that what I order is going to fit, because I don't want to get them on and find out that they rub when I turn out of the parking lot for the first time.
Here is what I'm thinking...
CCW 505A: http://www.ccwheel.com/files/wheelprofiles-model.php?id=505a
I am definately going with 19 in but I'm not sure exactly how wide yet. I would prefer 11" wide in back and probably 9.5" in front. IF THEY WILL FIT.
I think I am going to go with Michelin Pilot Sport A/S tires.
I guess I want to know if I could fit a 295/30/19 on the 11" rears and a 255/35/19 tires on the 9.5" fronts.
I do NOT want to have to do any fender rolling/ cutting at ALL.
Please let me know your thoughts on my selections. I'd like to get this taken care of ASAP so I can order the wheels/ tires. Thanks in advance. :)
hey joey you should pm'ed steve jarvis he knows alot about fitments with wheels.
Ponny
SF's Cleanest
Ponny
Thanks man, I checked his wheel/ tire fitment guide in the FAQ section.
If I don't get any good responses to this thread within a day or so I'll shoot him a PM. Thank you. :)
Joey, man I envy you. CCW 505A's are my absolute 1st choice to, but in 18's. Go with Jarvis's wheel fitment chart. He has done a lot of research and he is dead on. The chart can be found on MKIV.com or T04R.com I think. I printed it off a long time ago, but not sure from where.
Hate to tell you but you aren't going to get your size choice without fender "work". The only reason I am not running 10's and 11's is because of that. My paint is 100% stock and in great shape and I won't take any chances with fender work screwing it up.
Good luck with it.
Harry
SF's Cleanest
James I'm probably going to keep the stockers.
Just incase I ever need a spare set or if I take it to the track or something...
Sorry man. :(
on my quicksilver with tein flex coilovers i have 295/19 Continental Contisport II Tires, as you may know, they are same as 315's. my fenders are not rolled or trimmed. 19x11 rims in rears, fyi.
on my white supra with stock suspension i have 19x10.5 rims in rears with 275 nitto 555 tires. no rolling, no modifications at all. no rubbing.
It's all about the one thing most people forget to mention, OFFSETS.
You may be able to run a 11" wheel, but I doubt you will do it with a 295/30R19. Plus the tire you mentioned isn't available in a 295.
If you want to stick with the Michelin, than I would recommend a 19x11" +52mm offset with a 285/30R19 for the rear.
On the front I would recommend the following. A 19x9.5" +50mm offset wheel with a 275/30R19.
I currently run a 285 front and 295 rear with stock fenders, so don't worry.
Later, Steve
1 - 20 of 47 Posts
